Mach Discussion => General Mach Discussion => Topic started by: Ed123 on May 22, 2013, 06:13:13 PM
I have calibrated all axes and they measure what I put into the software.
However, when running a simple rectangle program the dimensions are twice what they should be.
Any suggestions as to how to correct this.\?
You probably need to turn the velocity and accel way down from what they are now if your trying to use the auto calibrate. Best to do the math to arrive at your steps per for this reason. If you skip steps while doing the auto calibrate or have backlash that isn't taken up auto calibrate will not take that into consideration.
Thanks Bret. Will give it a try
Alos make sure that the scaling DROs are set to 1.
