Hello
Guest
it is
November 17, 2026, 11:30:36 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Wiring THC into Gecko board and plasma cutter
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Wiring THC into Gecko board and plasma cutter (Read 11545 times)
jjmueller
27
on:
May 21, 2013, 09:54:30 PM »
Ok, so I am including photos, I need to wirer my Proma THC into a Gecko G540 2-axis drive into my Hypertherm powermax 85.
Can someone help me with the wiring.
Including photos of the Proma and Gecko Drive board.
Jerry
Logged
jjmueller
27
Re: Wiring THC into Gecko board and plasma cutter
Reply #1 on:
May 21, 2013, 09:55:39 PM »
Sorry its a 4-axis not 2. Typo
Logged
Carnoustie, Scotland
Reply #2 on:
May 25, 2013, 07:22:40 PM »
What exactly are you needing the help on and do you have a link to the manual for the proma?
Logged
jjmueller
27
Reply #3 on:
June 02, 2013, 07:21:35 PM »
OK! I have most everything working now except that mach will not start the plasma, I have the relay wired into the g540 at output 1 pin 17 and I can push the torch on the screen in mach and it works but just doesn't on a part. Maybe this is a problem in the Gcode since I only have the demo sheetcam right now. Can someone look at the code a tell me if this is so. just did a simple square to try the machine out
Logged
Print
Pages:
1
Go Up
« previous
next »
