Hello
Guest
it is
November 13, 2026, 01:32:11 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Printer port
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Printer port (Read 12707 times)
Ed123
6
Printer port
on:
May 19, 2013, 02:01:42 PM »
I downloaded Mach3 as instructed and did the reboot before using Mach3. However, when I go to tune the axis Mach3 does not allow me to select the axis I wish to set. Also when in the program option I cannot jog the axes. I assume that the printer driver is not loaded in the computer.
The computer is a refurbished Dell OptiPlex Gx620 with windows 7. Is there a driver I can download to fix this Problem?
ger21
6,295
Re: Printer port
Reply #1 on:
May 19, 2013, 02:06:42 PM »
Did you set up the ports and pins for the axis?
Ed123
6
Re: Printer port
Reply #2 on:
May 19, 2013, 06:29:58 PM »
Yes, the Port is set at 0x378.
The motor outputs are x=2. y=4, z-6
input signals are x=3, y-5, z=7
the Dir LowActive are all green as well as step low Active.
Step port and Dir Port are all set at one.
ger21
6,295
Re: Printer port
Reply #3 on:
May 19, 2013, 06:41:20 PM »
Are you using a 64 bit version of Windows 7? If so, The parallel port can't be used.
Ed123
6
Re: Printer port
Reply #4 on:
May 19, 2013, 06:58:07 PM »
No. I double checked the specs and it is a 32 bit computer.
TOTALLYRC
872
Re: Printer port
Reply #5 on:
May 23, 2013, 01:41:04 PM »
Make sure on the motor outputs tab you have checked the enable for the axis that you want to run.
Mike
Print
Pages:
1
Go Up
« previous
next »
