Hello Guest it is November 22, 2026, 09:27:47 PM
Author Topic: power control of router using mach 3 / M3  (Read 11602 times)
« on: May 17, 2013, 01:49:45 PM »
is it possible to use mach 3 M3 spindle control to turn on and off a porter cable router ?, if so how would you do it ?, use a relay ?, if so what kind,  has anyone done this ?
Re: power control of router using mach 3 / M3
« Reply #1 on: May 17, 2013, 09:31:54 PM »
Not the cheapest way, but the best way is to get a Super PID, which also gives you rpm control in Mach3.
www.superpid.com
« Reply #2 on: May 17, 2013, 11:20:44 PM »
Super cheapest (in stark contrast to the above!  ha ha) would be to tie a transistor onto a pin (just assign that pin as the spindle control), have the transistor fire a relay on/off.
« Reply #4 on: September 04, 2013, 03:18:17 PM »
I am trying to switch my spindle on/off through pin 1, output 1. The problem is that whatever I do the output 1 is allways low. When I switch off the computer it get high. I measured pin 1 of the parallel port and I allways get 4,something Volts idependent of the spindle button in mach 3 is on or off. Is that a problem with the parallel port? or is my breakoutboard that is defective? I have a probotix breakoutboard PBX-RF. Can anyone help?
« Last Edit: September 04, 2013, 03:19:50 PM by Sacramento »
