Hello
Guest
it is
November 22, 2026, 09:27:38 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
power control of router using mach 3 / M3
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: power control of router using mach 3 / M3 (Read 11598 times)
gigjoec
1
on:
May 17, 2013, 01:49:45 PM »
is it possible to use mach 3 M3 spindle control to turn on and off a porter cable router ?, if so how would you do it ?, use a relay ?, if so what kind, has anyone done this ?
Logged
ger21
6,295
Re: power control of router using mach 3 / M3
Reply #1 on:
May 17, 2013, 09:31:54 PM »
Not the cheapest way, but the best way is to get a Super PID, which also gives you rpm control in Mach3.
www.superpid.com
Logged
dr.fiero
31
Reply #2 on:
May 17, 2013, 11:20:44 PM »
Super cheapest (in stark contrast to the above! ha ha) would be to tie a transistor onto a pin (just assign that pin as the spindle control), have the transistor fire a relay on/off.
Logged
ger21
6,295
Reply #3 on:
May 18, 2013, 06:18:52 AM »
CNC4PC has several relay board options, as well as the relay itself.
http://www.cnc4pc.com/Store/osc/product_info.php?cPath=24&products_id=518
http://www.cnc4pc.com/Store/osc/product_info.php?cPath=24&products_id=357
Logged
Sacramento
6
Reply #4 on:
September 04, 2013, 03:18:17 PM »
I am trying to switch my spindle on/off through pin 1, output 1. The problem is that whatever I do the output 1 is allways low. When I switch off the computer it get high. I measured pin 1 of the parallel port and I allways get 4,something Volts idependent of the spindle button in mach 3 is on or off. Is that a problem with the parallel port? or is my breakoutboard that is defective? I have a probotix breakoutboard PBX-RF. Can anyone help?
Last Edit: September 04, 2013, 03:19:50 PM by Sacramento
Logged
Print
Pages:
1
Go Up
« previous
next »
