Hello Guest it is November 13, 2026, 01:28:40 PM
Author Topic: Problem with Run From Here in R3.043.066  (Read 26591 times)
Re: Problem with Run From Here in R3.043.066
« Reply #10 on: May 09, 2013, 04:00:56 PM »
I am not sure, its unlikely but you never know. Having said that if it works fine in an older version then I dont think the screenset is the issue.
« Reply #11 on: May 09, 2013, 08:39:59 PM »
The screenset should really have no effect on the way Mach3 runs at all, except when the macros that are supplied with it are running. The 2010 Screenset does Run From Here exactly the same as the standard screenset, with a button calling the system function "Set Next Line".
« Reply #12 on: May 10, 2013, 12:22:20 AM »
Gerry,
Thanks for your comments also.  Where is the Set Next Line function call located?  If you know.
Thank you.
« Reply #13 on: May 10, 2013, 06:00:55 AM »
It's an internal function that you assign in the Screen editor. It's the "Run from Here" command, but it's called "Set Next Line in the screen designer.
« Reply #14 on: May 10, 2013, 06:07:29 AM »
How do you access it?  I would like to compare what is in 66 and in my older version.
« Reply #15 on: May 10, 2013, 06:19:08 AM »
Open the screenset(s) in Screen4 and check what the button is assigned to do. either right click or double click the button to bring up it's properties.
« Reply #16 on: May 10, 2013, 07:08:18 AM »
Gerry,
Ok, that gives me the properties but I want to look at the code.  How do I find that?
« Reply #17 on: May 10, 2013, 07:30:06 AM »
There is no code, it's a built in function that can't be modified.
