Mach Discussion => General Mach Discussion => Topic started by: SailFl on May 08, 2013, 07:19:29 PM
I am having a problem with Run From Here in R3.043.066. I had an very old version of Mach and I recently moved to the current one. I use Run From Here with almost every cut I do and I cut a lot of acrylic and plywood. Today I had problems with Run From Here. I moved to a position and when pushed Cycle Start, the machine when to the right code but when I clicked Cycle Start afte it moved to went to the home position and cut on it way there. Also I noticed that after code went to the top of the file. It never did that before. In the past it would stay at the location I want to run from.
Have there been changes to this code?
I will be happy to provide additional details.
please attach your xml and I will have a look.
I can send my xlm, I first thought you wanted the file. I will have to send it later because I don't have a copy at home, it is at my shop. I will send later today. Thanks
One of my question I have has Run From Here been changed? In the older version I have when I did a RFH, the screen never showed the start of the file. When you high lighted the line number of where you wanted to start, click on Cycle Start, the machine would move to the new location and the cursor in the gcode window remained at the same line number. Then when I hit CS, it started to process the line that I picked to RFH.
Now when I hit CS the first time, the machine moves to the RFH location but the gcode window and the cursor are at the top of the file. When I hit CS again, it starts cutting but jumps to the RFH line of code that I picked. It never worked this way in the older version and I do not like this.
On the file I first had problems it seemed to happen at the same line number.
I also cut another file and the same thing with the showing the top of the file but it cut correctly.
Tell me if you can still help if I send only part of the file?
Thanks for looking at this.
It is your xml file I require so that I can test and hopefully find out what your problem is.
The xml file is the file that holds all of your mach settings, it is located in the main Mach3 folder and has the name of the Mach profile you are using.
If you open Mach and look lower right of the main screen you will see what profile you are using, close Mach and go to the Mach folder and look for a file of that name with a xml file extension. Copy it to your desktop and rename it to SailFl.xml and use the additinal options button on the reply page to attach it.
Hood,
As I mentioned, I was thinking you wanted to look at the gcode. I caught that and modified the file. I will send the xlm file later today.
Thanks you for you assistance.
Here is the xml. I had a problem today again so I went back to the old version of Mach. I use the same xml file for both versions.
Thank you for looking at this.
Ok the xml looks fine, I wanted to check that out and make sure it runs as it should.
Anyway here is the procedure to do a Run From Here.
Click the Code window and scroll (with mouse wheel or slider at side of window) until you get to the line you wish to start from.
Click the Run From Here button.
Mach should run through the code and you should then get a message flashing in the Status bar telling you to press cycle start.
A pop up box will appear telling you where Mach will move to and ask you to OK it. You can also start the spindle from there as well but be aware unless you already have a spindle speed value set in the DRO it will not run, so it is important to have at least entered a value there or to have previously started and stopped the spindle or start your RFH just before a spindle call.
You click Ok and Mach moves, once it gets there you then press cycle start again and that is it done.
Yes that is the correct procedure and that is what I do. Normally in the code window, it does not go back to the top of the file but that is what is happening and then it head to the home coordinates. It happened again today.
When I returned to my previous version of Mach, it worked perfectly. That is why I suggested there is a problem with R3.043.066.
Any other suggestions?
There could well be an issue with 066 version. I know of quite a few problems with it and this could well just be another. I usually recommend uising an older version, anything from 056 up to 062 seems to work reasonably well.
I am using Screen 2010 could that be creating a problem? I will try 062 and see if I have the same problem.
I am not sure, its unlikely but you never know. Having said that if it works fine in an older version then I dont think the screenset is the issue.
The screenset should really have no effect on the way Mach3 runs at all, except when the macros that are supplied with it are running. The 2010 Screenset does Run From Here exactly the same as the standard screenset, with a button calling the system function "Set Next Line".
Gerry,
Thanks for your comments also. Where is the Set Next Line function call located? If you know.
Thank you.
It's an internal function that you assign in the Screen editor. It's the "Run from Here" command, but it's called "Set Next Line in the screen designer.
How do you access it? I would like to compare what is in 66 and in my older version.
Open the screenset(s) in Screen4 and check what the button is assigned to do. either right click or double click the button to bring up it's properties.
Gerry,
Ok, that gives me the properties but I want to look at the code. How do I find that?
There is no code, it's a built in function that can't be modified.
