Hello Guest it is November 13, 2026, 02:14:01 PM
Author Topic: Removing pierce delay from mach3 not possible.  (Read 13468 times)
« on: May 08, 2013, 08:20:54 AM »
Hello. I'm having a problem with removing pierce delay in Mach3 plasma. I use sheetcam for generating the gcode. I need the pierce timer completely gone for the laser application that i'm using at the moment.
What i have tried:
- Making sheetcam pierce delay = 0s
- Manually removing pierce delay from the gcode file (setting G04 = 0 or just remove it completely)
Any advace would be much appreciated. And i apologize if i posted this in wrong forum section.
Re: Removing pierce delay from mach3 not possible.
« Reply #1 on: May 09, 2013, 03:22:54 PM »
If you are using the spindle controls for firing your laser then you will likely always have a delay.
I think most use an axis for firing the laser but give tweakie a shout as he does a lot of laser stuff.
http://www.machsupport.com/forum/index.php?action=profile;u=10309
  •  9,377 9,377
« Reply #2 on: May 10, 2013, 03:52:58 AM »
Hi Tunfiskur,
You may find this article and the attached comments of interest http://hobbycncart.com/publ/cikkek/mach3_temaju_cikkek/switching_a_laser_under_mach_control/8-1-0-29
« Reply #3 on: May 10, 2013, 09:43:30 AM »
Thanks for the link. Very good read. I will look into these methods for sure  :D
