Hello
Guest
it is
November 13, 2026, 03:11:03 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Help! runaway machine
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Help! runaway machine (Read 21375 times)
greenene
84
Re: Help! runaway machine
Reply #10 on:
May 07, 2013, 06:57:15 AM »
Interesting interpretation re.,newer pc. I upgraded, thinking that a faster cpu would provide greater stepper stability. Anyway, are you saying that I should delete the macros?
Tony
Carnoustie, Scotland
Reply #11 on:
May 08, 2013, 01:44:14 AM »
I would try deleting the contents of the M6End macro and see if that helps, or you could just comment out the code in it if you wanted.
greenene
84
Reply #12 on:
May 08, 2013, 06:26:58 AM »
I'll give that a try. In the meantime, I have to watch those code sections where there's no M01, which is usually when I use code snippets.
thanks for the help.
tony
Reply #13 on:
May 08, 2013, 12:17:27 PM »
The other thing you could do is edit the M6Start macro to stop the spindle and stop motion and you could then choose the Auto Toolchange option. It would be very similar to what is happening with the stop spindle and wait option with the exception that the M6End macro is not used in Auto.
Print
Pages:
1
2
Go Up
« previous
next »
