Hello Guest it is November 22, 2026, 12:13:38 PM
Author Topic: no connection between the machine and pc, help please.  (Read 28574 times)
Offline Robhi
  •  138 138
« on: April 28, 2013, 05:10:36 PM »
Hello,
today I tried to test my machine, if everything is OK, like, home, limit, relay etc. but I was surprised that there is no connection between the machine and the PC. there is no led for the limits and home. mach3 is well installed, I guess, I rebooted the PC, pulse is excellent. I used soundlogic XML file. I have a PC with xp installed, administrator.. nothing  respond...lol
I do not know what is going on...
thanks for help
Re: no connection between the machine and pc, help please.
« Reply #1 on: April 28, 2013, 06:53:01 PM »
Do you have the correct port address set?
Offline Robhi
  •  138 138
« Reply #2 on: April 29, 2013, 06:00:04 AM »
Yes ,
am sure of that, par defaut 378 the first one, check it again for being sure 200%.
thanks Hood
Offline Robhi
  •  138 138
« Reply #3 on: April 29, 2013, 01:51:49 PM »
I have also another  PC, but where win7 is installed. I do not know if mach3 will work well with.
I can not test it because i can not know the address of the parallel port. I have attached 2 files, pics of the resource of the PCI,
you  might help me to know which one I should use as well as its correct address.
Robhi
« Reply #4 on: April 30, 2013, 06:22:41 AM »
The address to try on that other computer would likely be E800
Offline Robhi
  •  138 138
« Reply #5 on: April 30, 2013, 04:46:07 PM »
Merci Hood,
I tried on my win7, port e800 and port 807, but there is no use. I tried on winxp too 387 and 278 , the same thing, parallel port on diag page of mach3 shows only 7 or 8 green led, that is all what i have.. i do not know where the problem is
really i need your help.
Thanks again
Offline Robhi
  •  138 138
« Reply #6 on: April 30, 2013, 05:32:12 PM »
I have installed another PCI parallel port but I can not know the address, is written as the following:-
DFA0  - DFA7
DF98 - DF9F    this is the LPT2
DFE0 - DFE7
DFA8 - DFAF               LPT3
I do not know the exact address, I would like to try this, other wise I will change the PC.
another this, I am thinking that my be the PC that , port parallel that does not work?
thanks for your help
Robhi
« Reply #7 on: May 01, 2013, 06:57:31 AM »
Can you attach your xml?
Offline Robhi
  •  138 138
« Reply #8 on: May 01, 2013, 10:34:03 AM »
thankx
Offline Robhi
  •  138 138
« Reply #9 on: May 01, 2013, 10:36:54 AM »
Here is my file.
i have tried to change the address as you have told me, but nothing new. there is nothing on diag page.
It is always as the attached file.
thanks
