Hello Guest it is November 13, 2026, 12:00:56 PM
Author Topic: Im new to the Mach3 program  (Read 53545 times)
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
Re: Im new to the Mach3 program
« Reply #10 on: April 30, 2013, 10:02:48 AM »
Jaime - this is why I asked you to check the profile name bottom right and post your xml - it's the easiest way for us to check your setup without continually guessing.
Ian
Offline JAC
  •  57 57
« Reply #11 on: April 30, 2013, 11:21:28 AM »
Sorry I do that tonight. and I try again.  I let you know
Offline JAC
  •  57 57
« Reply #12 on: April 30, 2013, 10:52:07 PM »
Hi Ian and Dave I check my system again and  everuthing look ok but stillmy mototr no move.
My profile name its  MILL_JAC.
I also check my comupter port for signal and this its what I found out.
port #2 .16v pressing the - or +
port#3  3.23v when I press the  - and stay like that till i press the + then it goes to 0v  and same thing happen to the other Y,Z.
Also I check the drivers and when its done it said Mach1 test complite  OK
Offline JAC
  •  57 57
« Reply #13 on: April 30, 2013, 10:59:37 PM »
Im trying to atach some pics so you can check my stting but  for some reason I cant , its getting late now I try again tomoorow.
Thank you
Offline stirling
  •  2,188 2,188
  • UK
« Reply #14 on: May 01, 2013, 02:38:36 AM »
Jaime - I didn't ask for the NAME of your profile and I didn't ask you to post pictures. Please re-read my first reply and post your xml FILE.
Ian
Offline JAC
  •  57 57
« Reply #15 on: May 01, 2013, 04:26:07 PM »
OK. you talking about the one on mach3 folder under mach3mill.xml . I attache it tonight. sorry for all this confusion. Think Im trying to do  things too fast.
Thank you Ian
Jaime
« Reply #16 on: May 01, 2013, 06:05:29 PM »
if your profile name is MILL_JAC, your xml file will be named MILL_JAC.xml .
John
Offline JAC
  •  57 57
« Reply #17 on: May 01, 2013, 08:54:47 PM »
Hi John, thank you. Think I got it now.
Offline JAC
  •  57 57
« Reply #18 on: May 01, 2013, 09:00:31 PM »
Hi Ian, think this is what you been asking for since the begining. If not let me know and I look for it again,  sorry for all this trouble and thank you for all your time and help.
Offline stirling
  •  2,188 2,188
  • UK
« Reply #19 on: May 02, 2013, 01:05:17 AM »
XML looks fine so...
Looks like you have a 3.5V parallel port. If this is the case you'll need to either add a new 5V parallel port card or a BOB that will accept 3.5V in and provide 5V out.
Ian
