Hello Guest it is November 13, 2026, 12:00:37 PM
Author Topic: Im new to the Mach3 program  (Read 53543 times)
Offline JAC
  •  57 57
Re: Im new to the Mach3 program
« Reply #30 on: May 06, 2013, 09:44:56 AM »
Thank you Rich. I do that later today.  After that just need to take care of my motor vibration when its no moving and I can start trying to run my machine. I already contact the company where I get them from and they told me to try  couple things. hopefully my motor stop vibrating when its no moving.
Thank you to everybody for all the help. I let you know later what happen.
Jaime
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #31 on: May 06, 2013, 10:16:28 AM »
In Reply #19 and Reply #23 I was querying whether your parallel port could be 3.5V rather than the 5V that may be required by your drivers
...but I don't seem to be able to find your reply...
The thing is, if your driver requires 5V logic and your PP is 3.5V, this could be causing the driver to see an indistinct logic level which could be causing it to dither.
Ian
Offline JAC
  •  57 57
« Reply #32 on: May 06, 2013, 10:57:54 AM »
Hi Ian. I took care of that problem already. I contact the company where I got my computer from  they toll me to check couple things, my parallel port its 5v, and my PCI slots are 5v as well. out of my 3 motors only one vibrates.
thank you
Jaime
Offline JAC
  •  57 57
« Reply #33 on: May 06, 2013, 09:52:14 PM »
Hi, RICH . I did the softlimits already on my machine, but when I move the Z axis 1" on Mach3 screen DRO it only moves .127" ( I have a digital calipers set on my Z axis ). Same thing happens on X axis  and Y axis. what do I have to change on Mach3 program to make it 1:1 (inches).
thank you
Jaime
« Reply #34 on: May 07, 2013, 05:09:38 AM »
Are you jogging or using the command line to make a move?
Are your units in inches ?
Is the scale set to 1 for each axis ( scale is located next to the DRO)?
Post the current xml file that you are using.
« Last Edit: May 07, 2013, 05:11:52 AM by RICH »
Offline JAC
  •  57 57
« Reply #35 on: May 07, 2013, 09:41:06 AM »
Hi RICH. yes I jogging the axis. I set my machine for inches, and all the axis has the scale 1.  I already post my xml file, its on page 2.  I double check everything again when I get home later today . Iam at work now. and I repost my xml file again.
thank you
Jaime
Offline JAC
  •  57 57
« Reply #36 on: May 07, 2013, 03:43:17 PM »
Hi, RICH here is my xml file.
« Reply #37 on: May 07, 2013, 09:38:40 PM »
Your cycle jog step is set at 0.001" and the jog mode is continous in the flyout.
Set the step to 1" and change the jog mode to step.
Offline JAC
  •  57 57
« Reply #38 on: May 08, 2013, 10:00:28 AM »
Hi RICH,  I check that, and I see if I can check it, cause Im sending back one of my drives, thats why one of my motors was vibrating. they told me to send it back so its going to take more than a week before i get it back. If I have any problem finding where to change the jog step and modes I let you know.
thank you
Jaime
Offline JAC
  •  57 57
« Reply #39 on: May 08, 2013, 09:13:44 PM »
Ok RICH, I already change the jog step to 1 and the mode to step. I'll check it as soon as I get my new driver.
Thank you for all your help.
Jaime
