Hello Guest it is October 20, 2026, 04:02:54 PM
Author Topic: Spindle changes speed during program run  (Read 10296 times)
« on: April 27, 2013, 03:51:36 AM »
Hi guys, just have the issue with my Spindle.  It sometimes ignores my S code and goes to max rpm.  Sometimes it just increases the speed by itself. I can press the 'reset' button for the speed and it brings it back down.
I have no Idea how to fix this !!
Please help
Thanks guys,
Anthony. ??? ???
Re: Spindle changes speed during program run
« Reply #1 on: April 27, 2013, 04:44:44 AM »
Is the spindle override slider moving up?
« Reply #2 on: July 25, 2014, 09:01:41 PM »
HI Hood, sorry for the late reply !!! How do I check that?
AZ
« Reply #3 on: July 26, 2014, 03:51:31 PM »
Presume you are using a fairly recent version of Mach? If you are then there will be a slider for feed override on the screen. Is it increasing in size on its own? Also you should see a % readout above it, is that increasing on its own?
