Hello
Guest
it is
November 13, 2026, 11:05:26 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
If I upgrade to a newer version of Mach will I have to reset any settings?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: If I upgrade to a newer version of Mach will I have to reset any settings? (Read 10470 times)
Jackal
173
on:
April 26, 2013, 08:11:01 AM »
I am wanting to upgrade to a newer version of Mach3. Apparently, my version is the one that has the spindle reverse pulley bug. Was downloaded around July 2010 ( I think?
I know I can save my .xml file and reuse it. Are there any other settings that I need to make note of?
I have taken pictures of each screen, in the event that something happens and they have to be re-done completely.
JAckal
Logged
Everything is bio-degradable if you run over it enough with a lawnmower.
Chaoticone
5,624
Precision Chaos
Re: If I upgrade to a newer version of Mach will I have to reset any settings?
Reply #1 on:
April 26, 2013, 08:40:14 AM »
I recommend backing up your entire Mach3 folder to a thumb drive or somewhere safe. Not just when upgrading but just good practice in general. You will want to save any custom screen sets, macros, brains, licenses files, and xmls for sure.
Logged
If you could see the things I have in my head, you would be laughing too.
Jackal
173
Reply #2 on:
April 26, 2013, 01:19:23 PM »
Thanks Brett,
I appreciate the info.
Can I just install the newer version over the older one? Or, do I need to uninstall the older version?
Jack
Logged
Chaoticone
5,624
Precision Chaos
Reply #3 on:
April 26, 2013, 02:45:08 PM »
Yup, you can install over the older version. You should make sure your profile is named something other than the default Mach Profiles. Again, shouldn't be a problem if you have your xml backed up but good practice in any case.
Logged
Jackal
173
Reply #4 on:
April 27, 2013, 09:16:09 AM »
Thanks for the help. I'll post any problems or fixes encountered, to help others.
Jack
Logged
Print
Pages:
1
Go Up
« previous
next »
