Hello Guest it is November 11, 2026, 08:30:41 PM
Author Topic: Feed Hold with Torch Off on cnc plasma system  (Read 8772 times)
« on: April 25, 2013, 12:46:30 PM »
Hi;
We want to use mach3 with the G41 and G42 codes. The wish is that if we push feed hold the torch goes off and the thc rises up. And then if "start" pushed that the system goes again.
It this in any way possible.
It would be nice if a tool dia ( kerf ) change will take effect after the "start"
Any ideas ?
Many thanks in advance
Selim
Re: Feed Hold with Torch Off on cnc plasma system
« Reply #1 on: April 25, 2013, 08:04:56 PM »
It is possible to do all that BUT you will have to write the support code to make it all work as you want it to.
