Hello Guest it is November 13, 2026, 11:48:42 AM
Author Topic: m5 kills all outputs  (Read 26313 times)
« on: April 24, 2013, 03:46:14 PM »
Hi all,
I am excited to have a new ATC and spindle control all hooked up on my 24" x 24" Techno CNC!  However, before I can get started I have to sort out this funky minor issue:
m3 will start the spindle via the Gecko G540 (Port 1 Pins 14 & 1).  m5 stops it.
m101 activates Output 1 (Port 2 Pin3)  M102 de-activates Output 1.
m103 activates Output 2 (Port 2 Pin1)  M104 de-activates Output 2.
However, for some reason, M5 also de-activates both outputs.  Output 1 re-activates after a moment, Output 2 remains deactivated.
I had a similar problem when I was making my solenoid bank and a diode on each helped eliminate feedback through the ground when the solenoid discharged.  Since there is now a diode on each solenoid - and more importantly, since the spindle is being fed from the G540 directly (not the solenoid bank) I'm confused about where the cross-feed is....
Any ideas?
dh
What am I missing?
Re: m5 kills all outputs
« Reply #1 on: April 24, 2013, 04:40:44 PM »
Additional info:
M5 doesn't de-activate inputs if the spindle isn't already running.  For example:
Activate output 1, enter m5 = Out1 is still activated.
Activate output 1, enter m3, enter m5 = out1 is deactivated.
So that made me think the motor is feeding juice through the ground to the rest of the system, but a) the G540's spindle outputs are opto-isolated and b) even Mach3's diagnostics screen shows the outputs being deactivated (it's not an electromechanical thing).
dh
« Reply #2 on: April 24, 2013, 05:10:46 PM »
Can you attach your xml and macros and I will test it out, also what version of Mach are you suing so I can test with the same version.
« Reply #3 on: April 25, 2013, 05:35:38 AM »
XML Attached.
Thanks!
« Reply #4 on: April 25, 2013, 03:21:31 PM »
Theres seems to be some strange things happening here with your xml, not sure why.
Will try and look a bit more and see if I can work out whats wrong.
« Reply #5 on: April 25, 2013, 03:43:56 PM »
Ok got the issue sorted that I was having with the VB editor, got Brett to open it on his dual screen and drag it back to the main screen and send me the new xml.
I have tried activating output 1 and then M3 and M5 and it is fine here, I dont have a ESS here so I am only testing with a SS.
I am wondering if it is something to do with the ESS, will see if I can test tomorrow on the big lathe as it has the ESS on it.
« Reply #6 on: April 25, 2013, 03:45:37 PM »
Can you send me your "new" xml?
dh
« Reply #7 on: April 25, 2013, 04:13:52 PM »
Here it is, be careful in case some other things have changed.
Can you attach the macros you are using for the outputs.
« Reply #8 on: April 25, 2013, 04:53:57 PM »
Hi Hood,
Thanks for taking the time to help with this - I'm nearly at my wit's end...
I checked your xml and the same thing is happening:  Activate outputs 1 & 2, start spindle.  When m5 is entered, output 2 deactivates (but not #1).
I thought maybe the ESS was ignoring Port #, which would cause a problem with output 2, as it is on pin 1 of Port 2 (the spindle uses pin 1 of Port1).  So I re-wired Output to Port2 Pin2.  ....Same problem....    >:(
« Reply #9 on: April 25, 2013, 05:06:16 PM »
ok... I "fixed" the problem....  Not sure why this works, but I changed my ActivateSignal (Output2) macro to ActivateSignal (Output3).  Then I configured Output3 to be EXACTLY the same as Output2 and disabled Output2.
So, M5 seems to disable Output2 regardless of port/pin setting?  I tried several different pins for output2 while stabbing in the dark and nothing seemed to protect it from M5.
