Hello Guest it is November 13, 2026, 09:44:13 AM
Author Topic: m5 kills all outputs  (Read 26303 times)
Re: m5 kills all outputs
« Reply #10 on: April 25, 2013, 05:09:24 PM »
Ah ok, so its output 2 :)
Try this go to Ports and Pins, Spindle Setup, enable the spindle relays, change M4 output to 6 then disable them again and apply.
« Reply #11 on: April 25, 2013, 05:12:02 PM »
Son of a....  Yep that's it.
Cheers, mate!!!
 ;D
« Reply #12 on: April 25, 2013, 05:14:52 PM »
M3 was already using 6, so now it's m3=5, m4=6; does that seem OK?
Next time you're in Boston, the first round's on me.
dh
« Reply #13 on: April 25, 2013, 05:19:33 PM »
That will be ok as long as you are not using outputs 5 or 6 for anything. M3 wasnt using 6 if I recall, the relays were set as 6 for M3 but they were disabled, think you have a step/dir spindle so no relays.
« Reply #14 on: April 25, 2013, 09:04:23 PM »
Icing on the cake:
Psyched to have everything sorted, I started putting misc. BOB's back together and getting cables re-routed back to their proper locations.  Unplugged the G540 and relay board, but somehow left the DC spindle motor plugged in.  Pulling the cord around, touched a bare end to the computer chassis... "pop!" "flash!"  Fried the Sherline Speed control board.  Laughing to keep from crying.  Will order another board tomorrow.
But cheers, anyway, Hood.  I really think the finish line is in sight (despite myself!).
« Reply #15 on: April 26, 2013, 01:57:08 AM »
Sorry to hear that but these things happen I suppose, if it hadnt happened now it likely would have at some point in the future.
« Reply #16 on: April 30, 2013, 04:49:33 PM »
Ok, I've replaced the Sherline Speed Control Board, but I'm getting no motion.  I REALLY hope I haven't fried the VFD output on the g540.  I know it's opticoupled, so does that mean it's safe?
In Mach, when I start the spindle, the Dwell light flashes once, but then stops and the spindle RPM has no readout.  I don't think I've changed any settings re: ports/pins....
« Reply #17 on: April 30, 2013, 05:10:55 PM »
LOL - I put the rocker switch in 180 degrees, so "On" was <<OFF>>  sheesh......
Up & running.  Still have a weird fluctuation in the spindle speed/sound, though....
