Hello Guest it is November 22, 2026, 05:28:48 PM
Author Topic: swap axis over in mach3?  (Read 10267 times)
Offline m9g
  •  26 26
« on: April 22, 2013, 03:11:09 PM »
Hi
I have bought an engraver and to me the X and Y axis are around the wrong way, they are setup as the manufacturer says with the long edge of the bed being Y and the short edge being X.
If I go into mach3 config and change the pins for X and Y will this swap them over? This would really help as the cnc's I have ever run have always been setup this way.
Regards
Re: swap axis over in mach3?
« Reply #1 on: April 22, 2013, 03:58:17 PM »
Yes that should be fine, normally the X axis runs parallel to where the user stands at the control panel.
Offline m9g
  •  26 26
« Reply #2 on: April 22, 2013, 04:11:02 PM »
Ok thanks, will try tomorrow, it would be nice to have the axis running the same as the one I run all day, starts messing with my brain after running a big cnc for 8 hours then coming home and my engraver is all back to front.
I've never come across a cnc running Y on the longer axis.
