Hello Guest it is November 23, 2026, 03:44:24 PM
Author Topic: Marcopump coding - returning back to saved fixture  (Read 11208 times)
« on: April 17, 2013, 12:31:21 PM »
Hello, everybody,
In making marcopump script, I want to save the current fixture number, I will use below code,
is it correct?
CurrFixture=GetOemDRO(46)
Then, the program will go to another fixture, let's say, G59 fixture:
Code"G59"
After running some activities, I want the program to go back original fixture, what DRO number
do I use? I can't figure it out...
Can somebody help and thanks in advance...
Re: Marcopump coding - returning back to saved fixture
« Reply #1 on: April 17, 2013, 09:19:01 PM »
The macropump is not a great idea with this type of operation as it reads and writes 10 times per sec. It would constantly be writing the dros.
I would simply use the G54 commands or any other fixture offset when you need them.
Just a thought, (;-) TP
« Reply #2 on: April 18, 2013, 04:18:05 AM »
Yes, I know it is running in 1/10 a second. There is an external button to control it, only when it is activated
the program will shift the machine to another fixture. I need to record the current fixture and go to another
one, afterward, go back to the original one.
There is function for feed, e.g. CurrentFeed=GetOemDRO(818) .....Code "F" &CurrentFeed
but there seems none for the fixture number.
Can anybody help..
« Reply #3 on: April 18, 2013, 10:13:39 AM »
Have you looked in  the Mach2 Customizing manual Page 6-3 ?
« Reply #4 on: April 18, 2013, 11:43:21 AM »
Is it -6.23 "Move to" control -that is on page 6-3 on Mach3 Manual?....don't understand if it relates to it...
You mention Mach2 customizing manual, is it same as Mach2 Manual?
« Reply #5 on: May 24, 2013, 03:00:28 PM »
You might try this code.
      'get first fixture number
FirstFixture= GetOemDRO(46)
      'Set the next fixture you want
Code"G54" 'or whatever
      'Do some code
     'Return to the first fixture
Code"G59P"& FirstFixture
« Reply #6 on: May 29, 2013, 10:23:49 AM »
Hello,
Before reading your reply, I got a way around by setting some offset variables in the marcopump program. Actually, I use them for the coordinates of my newly built toolchange box. So, whenever, I put the box to a new position, I need to update those variables. Althought it is not convenient, the whole setup works. Now, I already finished the toolchanger project and starts on another project. I do think your proposed code much useful for me as I only need to enter the coordinates of toolbox on a fixture, let say, G59. I don't need to go back the program to modify. I will get back on the project later to test it.
Many thanks...
