Hello Guest it is October 21, 2026, 07:53:05 AM
Author Topic: How could I calculate the step per revolution?  (Read 24858 times)
Offline Robhi
  •  138 138
Re: How could I calculate the step per revolution?
« Reply #10 on: April 19, 2013, 04:16:19 PM »
hello again, Brett and also other members too.
I have one or two questions please,
In the attached file (step per unit) I have to put 600 as you have told me, that is OK and it is so clear,
but what should I put , in the second attached file (encoder) in the count/unit as well as the velocity?
or should I let them empty? I guess it is so easy to let them empty LOL.
Thanks again for your help
Robhi
« Reply #11 on: April 19, 2013, 05:50:47 PM »
You dont need anything there, they are meant for encoder inputs to Mach if you want to have them. They have to be low resolution or the parallel port wont see them and even then they are only for users information as Mach does not act on them.
Offline Robhi
  •  138 138
« Reply #12 on: April 21, 2013, 01:24:56 PM »
Hello,
Thanks Brett and Hood and all other members too,
I Have more one question please, it is about The kernel speed. what do you think please, should I change it to 35000Hz or only let it as it sis, 25000Hz?
thanks again
Robhi
« Reply #13 on: April 21, 2013, 03:25:07 PM »
If you dont need more than 25KHz then it is best not to use more. If however you require it for more velocity then you will have to use more.
