Hello Guest it is November 27, 2026, 07:22:48 PM
Author Topic: How could I calculate the step per revolution?  (Read 25607 times)
Offline Robhi
  •  138 138
« on: April 17, 2013, 11:07:07 AM »
Hello every body.
I have servo motor for my future cnc. I have the following kit servo motor:-
  NEMA 34 Servo Motors 3 Axis CNC Kit:
NEMA34 Servo Motors 3 Axis CNC Kit(115VAC,230VAC):
3 PCS Geckodriver G320X, 80V/20A
3 PCS KL34-180-90 (NEMA 34) Dual Shaft, 1125 oz-in Peak 90V/40A
3PCS US Digital: E5-500-250-N-S-E-G-2 Individually
Packaged Shaft-Mount Optical 1/4" diameter shaft.
Molded mounting ears for 1.812" bolt circle (with
Installation Tool) for NEMA 34 Servo Motor
3PCS CA-FC5-SH-NC-6 Connector for 500 line or
250 line Encoder: 5-pin polarized conductor
shielded round 24 AWG cable. Standard
length is 6FT.
1 PCS KL-7220, 72V, 20A, Unregulated Power Supply, 110V/220V
1 pcs 5V Power Supply, 110V/220V
1 PCS C10 Breakout Board for 6 axis ( E-Stop or Limit Switch can be
wired)
I have a ball screw of 10mm pitch , with a pulley of 60 teeth on the screw. the second pulley which is mounted on the servo motor is 20 teeth, and the belt is T5. I also have Gecko 320x...
How could I calculate the step per revolution please?
I do not know if I give you all the information that you need.
thanks for you in advance for your help.
my unit is in mm.
thanks
Robhi
Offline Robhi
  •  138 138
Re: How could I calculate the step per revolution?
« Reply #2 on: April 17, 2013, 11:54:14 AM »
Hello Brett,
thanks for your reply, but I only found a stepper calculator, and nothing about servo motors,
I do not know how to do it with servo motor.
Robhi
« Reply #3 on: April 17, 2013, 12:01:45 PM »
What is the line count of your encoders?
Offline Robhi
  •  138 138
« Reply #4 on: April 17, 2013, 12:04:57 PM »
500 lines
Robhi
« Reply #5 on: April 17, 2013, 12:15:52 PM »
OK your steps per rev on your motor will be 2000 then I'm guessing. (500 x 4 for quadrature)
Offline Robhi
  •  138 138
« Reply #6 on: April 17, 2013, 12:22:07 PM »
ok I will try it later and let you know, thanks a lot for your great help.
Robhi
« Reply #7 on: April 17, 2013, 12:28:52 PM »
I get 6000 steps per mm
« Reply #8 on: April 17, 2013, 12:33:51 PM »
Nope, I think 600 steps per.  I just put 10 microsteps out of habit for geckos.
Offline Robhi
  •  138 138
« Reply #9 on: April 18, 2013, 06:24:42 AM »
Ok Brett, thanks too much, i will try it, hoping it will be ok...
thanks again
Robhi
