Hello Guest it is November 11, 2026, 07:55:17 PM
Author Topic: 8020 CNC Router  (Read 26748 times)
8020 CNC Router
« on: March 28, 2013, 07:56:38 AM »
Hello Guys
I have started another thread of me having trouble make the machine move. We are trying to figure it out what is wrong but in the meantime I will start this post to show my machine building process.  Maybe I will be able to help somebody with the build problems.
Here is the photo of rail I have use for my machine. I've purchased those from eBay. Recycled ones :-)
To cut the aluminum extrusions to the closest measurement as possible , first I set up a wooden stop block and then I cut a piece of wood and measure from block to the cut . If something were off a little I used a hammer to hit the stop block.
I've used my miter saw to cut the extrusions. Below is the picture of the saw and blade I used. Also I include a video showing how smooth was the cutting process :-)
Click on the picture below to see the video
All cut pieces
What is nice about 8020 aluminum extrusion is that you can purchased the profile with grooves which later on help you a lot to align the pieces together
Below I show you how I make my feet :-)
Main frame assembled
Ballscrews mounted
Machine feet mounted
Here I machined plates that will be used to connect ballscrews to gantry bottom plate
Z axis plate machined and mounted
Z axis actuator mounted
Not a best picture but this is bosch router mount
These are gantry side plates that holds everything together
And time to show my control box. I receive the box for free :-) and assembled everything myself
Fuses for each axis driver
I have not used these motors but I did use the dumpers
« Last Edit: March 28, 2013, 08:03:19 AM by Pysiek »
Re: 8020 CNC Router
« Reply #1 on: March 28, 2013, 08:08:45 AM »
Nice build. Thanks for showing.
Re: 8020 CNC Router
« Reply #2 on: March 28, 2013, 08:15:22 AM »
I will put more photos of the machine soon. But now I'm kind of busy with troubleshooting
Re: 8020 CNC Router
« Reply #3 on: March 28, 2013, 08:23:06 AM »
Looks very good!  Now it's time to see the beauty Queen dance!   ;D
Re: 8020 CNC Router
« Reply #4 on: March 28, 2013, 10:05:35 AM »
Very cool, thanks for sharing.
Who made the router mount, and what model Bosch does it hold?
Re: 8020 CNC Router
« Reply #5 on: March 28, 2013, 10:17:01 AM »
Router mount from CNC ROUTER PARTS http://www.cncrouterparts.com/bosch-1617-router-mount-p-192.html and router Bosch 1617 from eBay
Re: 8020 CNC Router
« Reply #6 on: March 28, 2013, 11:59:43 AM »
Thanks so much-
