Hello
Guest
it is
October 20, 2026, 06:02:34 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
external input as (shift on key board)
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: external input as (shift on key board) (Read 23905 times)
nso
36
Re: external input as (shift on key board)
Reply #10 on:
March 27, 2013, 07:46:11 AM »
hi
i tried today with 299 bypass feed rate but this is not result
Overloaded
4,923
Reply #11 on:
March 27, 2013, 01:47:19 PM »
Quite strange.
It doesn't work here now either.
Emulating the input with a hotkey did fine when first tried.
Emulation is working in Diagnostics, but no Bypass.
Hmmmm .... strange.
Very strange.
Carnoustie, Scotland
Reply #12 on:
March 27, 2013, 02:14:16 PM »
You could have a brain like screenshot below, that would set slow jog DRO to 100% with button pushed and set to 10% when released, obviously you can change the 10% value to what you normally use just by altering the formula in the brain.
Overloaded
4,923
Reply #13 on:
March 27, 2013, 03:21:20 PM »
Hi Hood,
Your little ditty works a treat here.
I like the way you manipulate the system.
I still can't understand why the other worked for a short time, then crapped out.
I wont let it worry me though as your way seems to be solid.
Russ
Overloaded
4,923
Reply #14 on:
March 27, 2013, 03:25:33 PM »
A cool thing about your way, you can change the % dro by manual entry to whatever you like and it will stay there while jogging ... even using the Shift key. It only reverts back to the lower Brain setting after hitting then releasing the external button.
Nifty.
Thanks again,
Russ
Reply #15 on:
March 27, 2013, 06:41:07 PM »
Yes Russ, the Brain only sees the transition so will only change the DROs when the button is pressed or when it is released, all other times you are free to write to the DRO.
nso
36
Reply #16 on:
March 27, 2013, 10:15:38 PM »
dear russ /hood i guess,it is best solution for me...
thanks a lot
Print
Pages:
1
2
Go Up
« previous
next »
