Hello Guest it is October 20, 2026, 03:04:18 PM
Author Topic: external input as (shift on key board)  (Read 23897 times)
Offline nso
  •  36 36
« on: March 26, 2013, 08:42:07 AM »
hi
 when slow jog rate set then arrows will jog at the slow speed and shift + arrows will jog at 100% and when release shift key go back at jog slow .
now i want do that with external (input1) push button.after search on oem button code i cant find any code for doing this..
please adviceto me
thanks
Re: external input as (shift on key board)
« Reply #1 on: March 26, 2013, 09:50:00 AM »
Have you tried oem button 287?
« Reply #2 on: March 26, 2013, 10:13:26 AM »
I can't find this either.
287 doesn't seem to work, tried several others .... no luck.
I do notice OEMLED 58 lights when the SHIFT key is hit.
Maybe this is internal ? ? ? ?
Russ
« Reply #3 on: March 26, 2013, 10:26:55 AM »
Yup, saw that so deleted the suggestion........
A brain monitoring an led that is on while the button is pressed setting jog to 100% and back to previous if led is off would work but think there is a button for it already.  The problem with the rapid jog in a vb button is the same as a jog button.  Vb isn't smart enough to detect on release.
« Reply #4 on: March 26, 2013, 10:31:41 AM »
Yup Russ, I think your right.  Turning on led 58 may be the way to go.
« Reply #5 on: March 26, 2013, 10:32:59 AM »
299 Bypass Feedrate, that's the cookie.
« Reply #6 on: March 26, 2013, 10:35:52 AM »
« Reply #7 on: March 26, 2013, 10:36:45 AM »
Thanks Russ............... need a note on that one. LOL  Searched for jog, rapid, never even thought of feed................ since it only affects jogging......  ::)
« Reply #8 on: March 26, 2013, 10:44:09 AM »
If you update your .xls, let us know so we can get the new one.
It's not really clear the way it is.
Thanks Brett,
Russ
Offline nso
  •  36 36
« Reply #9 on: March 26, 2013, 01:28:30 PM »
hi
first of all , thanks for your quick replay ( Overloaded and Chaoticone)
so, tomorrow test with brain... and  say what is happens  ;)
ahaa , i tried  led 58 ..that is my first idea  ;D but not work
thanks
