Hello Guest it is October 21, 2026, 02:28:31 PM
Author Topic: New type Mach3 conversational PAGE  (Read 14878 times)
« on: March 24, 2013, 01:56:57 PM »
OK I have been playing again. Sence the New Mach3 Wizard is OUT and running I thought that the Gcode programmers out there needed a function for creating Gcode programs from the command line approach.
From this page you can create a Gcode program directly into Mach3 and VIEW the toolpath  ONSCREEN  as you add to the File.
(button) Create the header and safety block for the file and loaded into MACH3 so it is veiwed on the toolpath.
(button) add Gcode commands to the file and update the program and toolpath for each line.
(Button) Complete the file and assign a FIlename and reload into MAch3.
I can be done as a new PAGE or a WIZARD.
Just a thought, (;-) TP
« Last Edit: March 24, 2013, 01:58:39 PM by BR549 »
Re: New type Mach3 conversational PAGE
« Reply #1 on: March 24, 2013, 04:57:55 PM »
Nice TP!
« Reply #2 on: March 24, 2013, 11:58:40 PM »
How is this downloaded for use? It looks like something I could use.
  •  9,374 9,374
« Reply #3 on: March 25, 2013, 02:35:11 AM »
Nice work Terry.  ;)
« Reply #4 on: March 25, 2013, 11:34:59 AM »
Captain it is just something I have running here. How would you want it ? As part of your screen set OR as a Wizard?
« Reply #5 on: March 25, 2013, 12:08:47 PM »
Maybe added to the wizards in my screen set?
« Reply #6 on: March 25, 2013, 12:58:06 PM »
I will build one for you to try (;-)
« Reply #7 on: March 25, 2013, 03:45:06 PM »
I placed the Conversational Wizard in the MACH TOOL BOX.
« Reply #8 on: March 25, 2013, 07:14:49 PM »
Thank you so much.
