Mach Discussion => General Mach Discussion => Topic started by: BR549 on March 24, 2013, 02:56:57 PM
OK I have been playing again. Sence the New Mach3 Wizard is OUT and running I thought that the Gcode programmers out there needed a function for creating Gcode programs from the command line approach.
From this page you can create a Gcode program directly into Mach3 and VIEW the toolpath ONSCREEN as you add to the File.
(button) Create the header and safety block for the file and loaded into MACH3 so it is veiwed on the toolpath.
(button) add Gcode commands to the file and update the program and toolpath for each line.
(Button) Complete the file and assign a FIlename and reload into MAch3.
I can be done as a new PAGE or a WIZARD.
Just a thought, (;-) TP
Nice TP!
How is this downloaded for use? It looks like something I could use.
Nice work Terry. ;)
Captain it is just something I have running here. How would you want it ? As part of your screen set OR as a Wizard?
Maybe added to the wizards in my screen set?
I will build one for you to try (;-)
I placed the Conversational Wizard in the MACH TOOL BOX.
Thank you so much.
