Hello Guest it is November 25, 2026, 10:38:48 PM
Author Topic: Have someone a solution for this issue?  (Read 10375 times)
« on: March 23, 2013, 01:23:25 PM »
Hello Together
I use a mill and a lathe. Both with Mach3 . Now I work offten with more tools and sometimes If I correct a measure , I want to get in the program on the tool I have done a correction.
I choose the line I want to get in ...push the green N ( or start from here ) but it didn´t work.  Have someone the same problem with this.
I got this issue on both machines.
Thank You
Re: Have someone a solution for this issue?
« Reply #1 on: March 23, 2013, 01:39:50 PM »
I presume you are meaning Run From Here?
If so then it does not work with demo version of Mach.
« Reply #2 on: March 23, 2013, 02:56:39 PM »
Hello Hood
Its already licensed now. But anyway it didn´t work.
Specialy now on the lathe where after the threading issue I put in the license once more... But threading now is fine  ;D
« Reply #3 on: March 23, 2013, 04:30:25 PM »
If you attach the code and your xml and tell me which line you are trying to do the Run From Here from I will see if I can find the issue.
