Hello Guest it is November 13, 2026, 07:13:33 PM
Author Topic: Correction of Z axis position  (Read 6794 times)
« on: March 18, 2013, 01:16:39 PM »
Hello,
I'm working on a mill machine, using Mach 3, that it is somehow mechanically damaged and, when it vibrates, it tends to lower the tool (mechanically) without changing the Z coordinate in the software. Could somebody help me to make a G-code to use the PROBE(G31) to automatically correct the Z position of the tool so that it changes the Z value of the actual tool position.
Thank you for your input.
Re: Correction of Z axis position
« Reply #1 on: March 18, 2013, 01:45:48 PM »
You need to fix the "machine" as a software approach will never work correctly for accurately machining parts.
Just a thought, (;-) TP
