Hello Guest it is November 13, 2026, 03:14:52 PM
Author Topic: Mach3 Bug? Causing overrun of drives  (Read 48944 times)
Re: Mach3 Bug? Causing overrun of drives
« Reply #30 on: June 13, 2013, 05:09:10 PM »
Are you running on board graphics or do you have a graphics card?  Adding a card may fix you up.
Offline P_D_B
  •  35 35
« Reply #31 on: June 13, 2013, 05:13:52 PM »
Graphics card but it is low end.  It is a PCIe 16 first generation slot.
Remember Einstein said this...."We can't solve problems by using the same kind of thinking we used when we created them."
__________________________________
Pete
Offline P_D_B
  •  35 35
« Reply #32 on: June 13, 2013, 05:16:07 PM »
What about an HD7750.  I don't know how much it would help since the slot is not 2.0 or 3.0.
Pete
« Reply #33 on: June 13, 2013, 05:28:25 PM »
With 600,000 lines of code, I think regardless of the video card, you'll want to turn off the toolpath display. It's a very common issue, as the display is very resource intensive.
Offline P_D_B
  •  35 35
« Reply #34 on: June 13, 2013, 05:58:33 PM »
Understood.  Thanks All
Pete
