Hello Guest it is November 13, 2026, 01:54:05 PM
Author Topic: Mach3 Bug? Causing overrun of drives  (Read 48918 times)
Offline P_D_B
  •  35 35
Re: Mach3 Bug? Causing overrun of drives
« Reply #10 on: March 17, 2013, 02:53:31 PM »
Maybe one of you can help me understand why this helped.  I went into motor tuning and decreased my velocity to 400 ipm then tried the program.  Still the same problem.  So I went back to motor tuning and increase my acceleration to 40 (10%) of velocity.  Now the program runs.  A little better explanation of how these two relate would be helpful.
Thanks in advance
Remember Einstein said this...."We can't solve problems by using the same kind of thinking we used when we created them."
__________________________________
Pete
« Reply #11 on: March 17, 2013, 03:11:35 PM »
There was a bug a while back in Mach that could cause issues if Z axis was quite a bit different in tuning than X and Y. Ray should be able to fill you in more on that as I am sure he suffered from it. I would have to search back to see so hopefully Ray will chime in.
Anyway I am thinking thats unlikely to be your problem as yours were not that far off each other and unless you have adjusted the Z to the same as X and Y they will actually be further out now.
Offline P_D_B
  •  35 35
« Reply #12 on: March 17, 2013, 03:18:47 PM »
Hood,
I made all axes the same
Pete
Pete
« Reply #13 on: March 17, 2013, 03:22:06 PM »
Still think its a long shot as I was sure the Z had to be way out compared to other axes but maybe not, Ray will be able to say for sure.
What Rev of Mach are you using?
Offline P_D_B
  •  35 35
« Reply #14 on: March 17, 2013, 03:55:51 PM »
Version R3.043.022
Pete
« Reply #15 on: March 17, 2013, 05:20:40 PM »
IIRC, v3.043.022 is the version I had that problem with.  However, it was only an issue when the Z axis was set for lower velocity/acceleration than the other axes, and only when transitioning from a 2-axis arc move to a three-axis move.  Mach3 would ignore the Z axis acceleration, and command it to accelerate at the rate of the other two axes, which, of course Z could not do.  I've been told it was fixed quite some time ago.
Have you tried running with a more recent version of Mach3?  That one is quite old.
Offline P_D_B
  •  35 35
« Reply #16 on: March 17, 2013, 05:27:07 PM »
No, I have not upgraded yet.  Few reason why, 1) just was thinking about it the other day but was unsure if it required purchasing again 2) Do not know what all I will have to start over from the beginning again. Whether I will have to redo all brains, screensets and settings.
Pete
« Reply #17 on: March 17, 2013, 05:43:23 PM »
You shouldn't have to start over at all or buy another licenses.  It would be a good idea to make a copy of your entire C:/Mach3 folder and put it on a thumb drive before any changes, but this is always true and just precautionary.  You should be able to just download and install.  I wouldn't get the development or lockdown on the downloads page right now.  We haven't nailed anything down yet but quite a few suspect problems with them.  I'll let Ray recommend a version.  I'd say 3.043.056 or .057.
ftp://machsupport.com/Mach/
« Reply #18 on: March 17, 2013, 05:46:09 PM »
Brett,
I can't recommend a version - I stopped using Mach3 well over a year ago.
Offline P_D_B
  •  35 35
« Reply #19 on: March 17, 2013, 06:07:28 PM »
Ray,
I have to ask Why you quit using Mach?
Pete
