Hello
Guest
it is
November 13, 2026, 09:44:03 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Mach3 Bug? Causing overrun of drives
« previous
next »
Print
Pages:
1
2
3
4
Go Down
Author
Topic: Mach3 Bug? Causing overrun of drives (Read 48902 times)
Chaoticone
5,624
Precision Chaos
Re: Mach3 Bug? Causing overrun of drives
Reply #30 on:
June 13, 2013, 05:09:10 PM »
Are you running on board graphics or do you have a graphics card? Adding a card may fix you up.
Logged
If you could see the things I have in my head, you would be laughing too.
P_D_B
35
Reply #31 on:
June 13, 2013, 05:13:52 PM »
Graphics card but it is low end. It is a PCIe 16 first generation slot.
Logged
Remember Einstein said this...."We can't solve problems by using the same kind of thinking we used when we created them."
__________________________________
Pete
P_D_B
35
Reply #32 on:
June 13, 2013, 05:16:07 PM »
What about an HD7750. I don't know how much it would help since the slot is not 2.0 or 3.0.
Logged
Pete
ger21
6,295
Reply #33 on:
June 13, 2013, 05:28:25 PM »
With 600,000 lines of code, I think regardless of the video card, you'll want to turn off the toolpath display. It's a very common issue, as the display is very resource intensive.
Logged
P_D_B
35
Reply #34 on:
June 13, 2013, 05:58:33 PM »
Understood. Thanks All
Logged
Pete
Print
Pages:
1
2
3
4
Go Up
« previous
next »
