Hello Guest it is November 03, 2026, 08:49:01 AM
Author Topic: Still breaking bits... Jump start from a mid run stop...  (Read 12094 times)
VOTS
« on: February 06, 2007, 09:24:06 PM »
I'm using very small diameter bits (1/16 and smaller) to cut out my widgets with. So far I've snapped off about $50 bucks worth. Lubrication helped allot, slowing down the feed rate helped... but... If I stop the run, and then restart it, it goes into over drive. I had it happen with a 1/8th bit and it actually survived something like a 50in per min rate when it jumped. Of course, the aluminum I was cutting looked like it had been ripped apart, not milled. When this happens with the smaller bits, *poink* more money down the drain. Is this a bug in the software? Anyone else run across this?
Re: Still breaking bits... Jump start from a mid run stop...
« Reply #1 on: February 06, 2007, 10:29:52 PM »
What version of Mach are you running?
VOTS
« Reply #2 on: February 07, 2007, 12:00:46 AM »
Mach3 R1.84.001, just downloaded it couple weeks ago to make sure I had the latest
« Reply #3 on: February 07, 2007, 01:35:23 AM »
R2.00.044 is the latest and will probably be the best as most bugs have been ironed out.
VOTS
« Reply #4 on: February 07, 2007, 06:37:30 AM »
Hrmmm...
I see that now, ok, downloading. Thanks gents.
