Mach Discussion => General Mach Discussion => Topic started by: VOTS on February 06, 2007, 10:24:06 PM
I'm using very small diameter bits (1/16 and smaller) to cut out my widgets with. So far I've snapped off about $50 bucks worth. Lubrication helped allot, slowing down the feed rate helped... but... If I stop the run, and then restart it, it goes into over drive. I had it happen with a 1/8th bit and it actually survived something like a 50in per min rate when it jumped. Of course, the aluminum I was cutting looked like it had been ripped apart, not milled. When this happens with the smaller bits, *poink* more money down the drain. Is this a bug in the software? Anyone else run across this?
What version of Mach are you running?
Mach3 R1.84.001, just downloaded it couple weeks ago to make sure I had the latest
R2.00.044 is the latest and will probably be the best as most bugs have been ironed out.
Hrmmm...
I see that now, ok, downloading. Thanks gents.
