Hello Guest it is November 13, 2026, 01:33:16 PM
Author Topic: Mach 3 + Gecko G540 + Saj-8000 series invereter  (Read 11476 times)
« on: March 12, 2013, 07:00:01 PM »
This is my first post and wish I found this forum ages ago.
I am nearing the end of my first CnC build and am having a ball.
I have all the axis going well Mach 3 screaming with code and loving it , my next task is to get my spindle talking to Mach3 via a Gecko G540 drive unit.
Nows the problem I have an SAJ8000 series inverter and cannot for the life of me fathom out the the wiring instructions.
The Gecko G540 looks straight forward but at the invereter end I cannot get the signage on the terminal blocks to make any sense.
I have attached a pic of the terminal block at the inverter end can anyone please help before I create some smoke.
Thankyou for reading.
Adrian
Re: Mach 3 + Gecko G540 + Saj-8000 series invereter
« Reply #1 on: March 12, 2013, 07:30:51 PM »
Looking at this manual found via Google,
www.fennecmachinery.com.au/SAJ%208000-M%20manual.pdf
Looking at the tables on page 18,19 and the diagram on page 22 , You need to connect the G540 VFD terminals as,
G540                                      VFD
Pos 9 VFD +10Vdc                    10V
Pos 8 VFD Output                     VI
Pos 7 VFD Ground                     ACM
Cheers,
Peter
Homann Designs
http://www.homanndesigns.com
« Reply #2 on: March 12, 2013, 07:58:09 PM »
Many thanks Peter the only thing that has been throwing me is the ACM quoted ,and the fact it has AM on the terminal block.
Adrian
« Reply #3 on: March 12, 2013, 08:05:47 PM »
Hi Adrian,
Have a look at your manual and see what the definition of the AM terminal is.
Cheers,
Peter
Homann Designs
« Reply #4 on: March 12, 2013, 08:07:23 PM »
According to the manual I found AM is an analog Monitor output an is not suitable as the Analog Common terminal.
Homann Designs
« Reply #5 on: March 12, 2013, 08:18:07 PM »
The manual I have is identical to the link you have posted thats why I am a little lost.
Adrian
