Mach Discussion => General Mach Discussion => Topic started by: A.Davis on March 12, 2013, 08:00:01 PM
This is my first post and wish I found this forum ages ago.
I am nearing the end of my first CnC build and am having a ball.
I have all the axis going well Mach 3 screaming with code and loving it , my next task is to get my spindle talking to Mach3 via a Gecko G540 drive unit.
Nows the problem I have an SAJ8000 series inverter and cannot for the life of me fathom out the the wiring instructions.
The Gecko G540 looks straight forward but at the invereter end I cannot get the signage on the terminal blocks to make any sense.
I have attached a pic of the terminal block at the inverter end can anyone please help before I create some smoke.
Thankyou for reading.
Adrian
Looking at this manual found via Google,
www.fennecmachinery.com.au/SAJ%208000-M%20manual.pdf
Looking at the tables on page 18,19 and the diagram on page 22 , You need to connect the G540 VFD terminals as,
G540 VFD
Pos 9 VFD +10Vdc 10V
Pos 8 VFD Output VI
Pos 7 VFD Ground ACM
Cheers,
Peter
Many thanks Peter the only thing that has been throwing me is the ACM quoted ,and the fact it has AM on the terminal block.
Adrian
Hi Adrian,
Have a look at your manual and see what the definition of the AM terminal is.
Cheers,
Peter
According to the manual I found AM is an analog Monitor output an is not suitable as the Analog Common terminal.
The manual I have is identical to the link you have posted thats why I am a little lost.
Adrian
