Hello Guest it is November 11, 2026, 11:13:50 PM
Author Topic: What does 'A-Rotations Enabled' mean?  (Read 8171 times)
« on: March 11, 2013, 07:29:23 PM »
I'm setting up my 4th axis (rotary).  In the Toolpath Configuration flyout there is a box for A-Roatations Enabled; should this be checked?  What does it do?
Offline Greolt
  •  956 956
Re: What does 'A-Rotations Enabled' mean?
« Reply #1 on: March 13, 2013, 09:35:59 PM »
"A-Rotations Enabled" tells Mach that the toolpath is of a rotary type for visual display purposes.
You must select this and the correct "Axis of Rotation" for the display to correctly represent the rotary toolpath..
Note;  you must also set the "Rotation Radius" DRO to represent the distance that the Z axis origin is offset from the centre of rotation.  Or the displayed toolpath will be out of whack.
Also note; only A axis toolpaths will display.  Not B or C.
Greolt
