Hello Guest it is November 11, 2026, 06:50:14 PM
Author Topic: ESS and Mach Lathe, which SW-Version?  (Read 16826 times)
Offline TomS
  •  17 17
« on: March 09, 2013, 09:50:57 AM »
Hello,
at many posts there are recommended Version 057 for lathe, but this will not with ESS, if i use the ESS, it is nessesary to use upper 062.
What is a good working version with ESS and lathe?
Best regards,
Tom
Re: ESS and Mach Lathe, which SW-Version?
« Reply #1 on: March 09, 2013, 04:18:49 PM »
I use 057 on the big lathe and it has an ESS, however I use an older plugin for the ESS, 10a I think. If you use one of the newer plugins then you will likely need 062 or newer. I think the problems with Turn started in 066 but cant be sure as I dont think I had anything newer than 057, except my trials of 066/7
Offline TomS
  •  17 17
« Reply #2 on: March 10, 2013, 04:38:55 AM »
Hello Hood,
thanks for your reply. Where i can get this early plugin? On the Warp9 site, there is the earlist Version 10eb1a (and there are big Problems with MPGs)
Best regards,
Tom
