Third party software and hardware support forums. => SmoothStepper USB => Topic started by: TomS on March 09, 2013, 10:50:57 AM
Hello,
at many posts there are recommended Version 057 for lathe, but this will not with ESS, if i use the ESS, it is nessesary to use upper 062.
What is a good working version with ESS and lathe?
Best regards,
Tom
I use 057 on the big lathe and it has an ESS, however I use an older plugin for the ESS, 10a I think. If you use one of the newer plugins then you will likely need 062 or newer. I think the problems with Turn started in 066 but cant be sure as I dont think I had anything newer than 057, except my trials of 066/7
Hello Hood,
thanks for your reply. Where i can get this early plugin? On the Warp9 site, there is the earlist Version 10eb1a (and there are big Problems with MPGs)
Best regards,
Tom
I posted it here
http://www.machsupport.com/forum/index.php/topic,21036.msg167619.html#msg167619
