Hello Guest it is November 30, 2026, 07:45:57 AM
Author Topic: homing slaved motors  (Read 18645 times)
0 Members and 4 Guests are viewing this topic.
« on: February 05, 2007, 09:45:58 PM »
X.Z and A all move to home position with X and Z backing off .25" as they are supposed to.  A is staying at home as it is supposed to.  Y and B are slaved together Y moves toward home switch but B doesn't move.   Slaved motors work fine during normal operations.  Y and B should move to home position until Y reaches switch and then both stop.
Re: homing slaved motors
« Reply #1 on: February 05, 2007, 11:11:20 PM »
Can you post your xml for us to see?
« Reply #2 on: February 06, 2007, 10:21:12 AM »
here is the file
« Reply #3 on: February 06, 2007, 10:36:19 AM »
On that xml, Y and B are not slaved and the motor tuning for the two are not the same. I can't check it like I would like, not enough dro's. ;D
I have sent you a personal message.
« Reply #4 on: February 06, 2007, 12:17:19 PM »
Here is file with Y and B set equal.  Confirmed that Bis running slaved in normal operations.  If I read it correctly motor 2 is primary with 1 slave but mo motor is listed as slave.  No web access available at this time.
« Reply #5 on: February 06, 2007, 12:33:10 PM »
I think we have a bad XML upload. The problem could be coming from my end, not sure. Can you upload it one more time.
« Reply #6 on: February 06, 2007, 01:20:10 PM »
here it is
« Reply #7 on: February 07, 2007, 05:58:11 AM »
Also I tried to set X,Y,Z and A lower case as hotkeys to home their respective axis.
« Reply #8 on: February 07, 2007, 04:59:26 PM »
Check to see that you have the same homing %speed and that you have the Homing turned on for the B axis
www.newfangledsolutions.com
www.machsupport.com
Offline Bloy
  •  158 158
« Reply #9 on: February 08, 2007, 07:47:47 PM »
If I read this correctly, you have only one homing switch for Y?   In that case, you need to have a homing switch for both Y AND B.
then to syncronize them to keep the two sides in line, move one or the other switch until they make your gantry square.
I hope this is what you are takling about....
