Hello Guest it is November 13, 2026, 10:20:26 AM
Author Topic: waiting/calculation time inbetween passes  (Read 15001 times)
« on: March 05, 2013, 06:01:32 AM »
Hi Guys,
I am looking for a solution for my problem:
At the end of each pass  my tool is not moving for lets say half a second : this causes extra wear of my tools. (using g01 codes)
(Mach3 seems to need some execution/calculation time before starting the next pass)
Do i need a faster computer or can i use a command/change settings  that speeds things up?
thanks
Mark
Re: waiting/calculation time inbetween passes
« Reply #1 on: March 05, 2013, 07:50:08 AM »
Post your code and xml file and I'll take a look.  Sounds like you have some weirdness going on.
« Reply #2 on: March 08, 2013, 04:14:24 AM »
Hello Brett, thanks for your kind reply.
« Reply #3 on: March 08, 2013, 04:18:09 AM »
Brett, could it be an    exact stop mode   issue ?
« Reply #4 on: March 08, 2013, 09:25:05 AM »
Simulating your code here in your profile, I see no delay.  Have you checked your backlash?
« Reply #5 on: March 08, 2013, 09:29:13 AM »
Hi Mark and Brett
it's not CV causing this.
In General Config you checked " Z is 2,5 D on Output #6 "
UNCHECK this
Alex
« Reply #6 on: March 08, 2013, 09:42:51 AM »
Hi Alex /Brett : Thanks for both your replies .
Alex :  You were right Unchecking did the trick !!
thanks again
Mark
« Reply #7 on: March 08, 2013, 10:05:57 AM »
Good job Alex, Thanks,
« Reply #8 on: March 08, 2013, 10:48:06 AM »
Thanks Brett. ;D
Alex
