Hello Guest it is November 13, 2026, 02:15:19 PM
Author Topic: Need help converting HPGL files to GCode for my Mach3  (Read 12994 times)
« on: March 04, 2013, 11:14:31 AM »
Hi, I've been milling PCBs using Eagle then PCBGCODE then the OPTIMIZER. But, Eagle's size limitation is killing me. I had purchased a copy of SPRINT which outputs isolation milling files in a HPGL format. I dont know how to convert them to GCode. I really like the Eagle, but if switching to SPRINT allows me to make larger boards I'd drop Eagle in a second. What program can convert the HPGL files to GCode? Am I going about this in the right way? Any pointers would be appreciated!
Re: Need help converting HPGL files to GCode for my Mach3
« Reply #1 on: March 04, 2013, 11:27:36 AM »
Check out SheetCam it can deal with HPGL files.
  •  9,377 9,377
« Reply #2 on: March 05, 2013, 05:06:56 AM »
Hi Miles,
Welcome to the forum.
Try LazyCam (it comes free with Mach3) - it can convert HPGL(2) to GCode.
Providing the HPGL file size is not too large it makes a reasonable job, allows scaling and some limited editing etc.
