Hello
Guest
it is
November 03, 2026, 08:46:46 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Linear Encoders
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Linear Encoders (Read 10542 times)
cowpoke
31
Linear Encoders
on:
February 04, 2007, 08:55:30 PM »
Can someone provide a discussion as to the pros and cons of using linear rather than rotary encoders on a machine which will be using Mach?
I have an Italian machine which already has glass scale encoders and servos and would like to make use of them rather than having to special mount rotary encoders.
TIA.
CEM
Logged
Chip
2,055
Gainesville Florida USA
Re: Linear Encoders
Reply #1 on:
February 04, 2007, 10:02:28 PM »
Hi, CEM
Rotary encoders are mostly on the servo, no backlash, liner encoders can cause the servo to hunt back and forth depending on your
backlash between table/encoder and servo.
You'll find them used both ways.
Hope this Helps, Chip
Logged
jguillen
28
Re: Linear Encoders
Reply #2 on:
February 07, 2007, 10:48:56 PM »
I opted to mount the encoders directly to my ball screws. I have 3:1 timing pulllys between servos and ballscrews. Appart from some slight singing of the motors every thing works fine.
jose.
Logged
Print
Pages:
1
Go Up
« previous
next »
