Hello Guest it is October 22, 2026, 05:33:38 PM
Author Topic: Feed Rate Override  (Read 14822 times)
Feed Rate Override
« on: February 28, 2013, 09:50:56 AM »
Hi, This is probably a dumb question but if you use the on screen fro to speed things up, does it speed up the g0 speed?
i have notice that using it to lower the speed does effect the rapid move speed so does it do the same when you speed itup?
John
Re: Feed Rate Override
« Reply #1 on: February 28, 2013, 10:01:43 AM »
You can have the rapid locked to feed override but it will never go above 100% even if your FRO goes over 100%.
The option to lock Rapid to FRO is on general Config page.
« Reply #2 on: February 28, 2013, 02:02:02 PM »
Thank you Hood
John
« Reply #3 on: May 24, 2014, 05:56:59 AM »
My X and Y motors are set at 4000 units per minute. Z is set at 2000
Why does the X and Y travel at only 1000 when doing a safe Z move (moving onto the next position)
When the machine is actually milling material the X and Y are traveling at 1500, but the G0 is always at 1000
Cant I get the Rapid feed rate G0 to move at 1500 or even 4000 ??
« Reply #4 on: May 24, 2014, 08:28:10 AM »
Ok.. Done it.  In Mach3. Open the settings tab. Top left hand box called Fast feed overide. It has 0.00 in the box. I changed the numbers to 1000 and left the tab without pressing enter. Now It goes 5x as fast when not cutting material
« Last Edit: May 24, 2014, 08:31:12 AM by dudz996 »
