Hello Guest it is November 13, 2026, 09:48:37 AM
Author Topic: Pulsing  (Read 8587 times)
Pulsing
« on: February 19, 2013, 12:23:05 PM »
Hey Guys
So i was checking the setting's on Mach in my Machine and testing the driver i never saw this before but in came back saying i was pulsing the driver to high @ 35 and wanted to be @ 25 so  i set it to the lower number and went in to re-tune the motors but what i found was that no matter what i set the motor tuning to it did not change the speed so i set it back to 35 and now the motor's perform like they should question is should i be concerned about or just leave it alone.
Dennis
Re: Pulsing
« Reply #1 on: February 19, 2013, 12:40:07 PM »
You need to restart Mach before any revised kernel setting will take effect.
If its running fine at 35KHz then all should be fine, if you have any pulsing issues then 25KHz may be better.
Re: Pulsing
« Reply #2 on: February 19, 2013, 02:01:48 PM »
Thanks for the reply the system is working so i am going to leave it alone.
Dennis
