Hello Guest it is August 14, 2026, 03:49:10 PM
Author Topic: Problem with the homing sequence.  (Read 25477 times)
« on: February 18, 2013, 07:59:45 PM »
I am having an issue with homing. After a few gcode runs then shutting down for the night then starting up the next day mach 3 will not home all axis (the motors don't move but the indicators turn green). One time the Z axis would home but not x & y, once none of the axis would home, the last time only the x would home not z & y. The dro's for the axis of the motors that do not turn do not change.
I can restore from my backup of the particular custom profile and the homing process works again.
It seems as though mach 3 is the culprit most likely due to my lack of experience with this software.
Does anyone know what would cause this homing problem?
Re: Problem with the homing sequence.
« Reply #1 on: February 18, 2013, 09:38:16 PM »
Is this not the profile your running all the time?  To be clear, the machine homes as it should using one profile and will not home as it should using a different profile.  Is that right?  If it is, why aren't you using the profile that homes as it should all the time?  What has changed to require a different profile?
« Reply #2 on: February 19, 2013, 07:34:24 AM »
I have one profile that I use CNC_JR. That is the profile in which this situation occurs and that is the profile that I restore.
After further reading the manual this is what it appears is happening, although I am unsure of why.
"Homed true when no Home switches: This option will make the system appear to be Home referenced
(i.e. LEDs green) at all times. It should be used only if no Home switches are defined under
Ports & Pins>Input Signals tab."
My home switch inputs are still showing the correct pins and are enabled.
And some further information about things I have tried. I am using windows vista and I have installed the patch. I have cycled power to the usb controller. I have re-booted.
If I do not run gcode homing works fine after shutting down and restarting.
The only thing I am changing when I run gcode is the xyz zero and regen toolpath.
If this occurs again I will try to disable and then re-enable my home switches.
« Last Edit: February 19, 2013, 07:36:53 AM by frankbicknell »
« Reply #3 on: February 19, 2013, 08:52:41 AM »
USB controller? What is it? Also what version of Mach?
« Reply #4 on: February 19, 2013, 07:10:11 PM »
It is a  KL-CNCUSB-3x-breakout board. Mach 3 R3.043.066.
« Reply #5 on: February 20, 2013, 02:37:22 AM »
Ok never heard of that board but will do a search, in the mean time see if it happens with an older version of Mach. I have had a lot of issues in Turn with 066 and 067 and  found one in Mill with these versions as well so I wont use them now.
« Reply #6 on: February 20, 2013, 10:07:17 AM »
Thank you for your help. I purchased the products from www.automationtechnologiesinc.com. Where can I get an older version?
« Reply #7 on: February 20, 2013, 10:13:00 AM »
You can get older versions on the ftp site, if you go here http://www.machsupport.com/downloads.php you will see a link that says Click Here, it takes a wee while to load but you should see a folder called Mach and you will find the older versions in it.
« Last Edit: February 20, 2013, 10:18:04 AM by Chaoticone »
« Reply #9 on: February 20, 2013, 08:40:31 PM »
Thanks for all the help. I will try the older version and report back. It will take a couple of days.
