Hello Guest it is October 22, 2026, 07:55:06 PM
Author Topic: labels incorrect in mach3  (Read 15012 times)
« on: February 14, 2013, 01:42:27 PM »
i have machscreen 1.56 and made a .set. in it i have a MDI label.
near there is an inch/mm toggle. when i open mach3 the MDI label reads
inches. if i toggle the inch/mm button, it changes to mm's. every now and then
it will read right(MDI)
Thanks for any help
Kenneth
Re: labels incorrect in mach3
« Reply #1 on: February 14, 2013, 01:47:20 PM »
this is a picture
Kenneth
« Reply #2 on: February 25, 2013, 06:46:50 AM »
am i in the wrong foum for machscreen or mach3 ?
Kenneth
« Reply #3 on: February 25, 2013, 08:42:04 AM »
I would have to look at it in a screen designer to be doing anything but guessing.
« Reply #4 on: February 25, 2013, 09:15:15 AM »
Thanks Chaoticone
Kenneth
« Reply #5 on: February 26, 2013, 03:30:12 AM »
Hi Kenneth,
as Brett said, we would need to have your screenset file to have a deeper look at it. If you would email it, I'll have a look at it.
My email  addr: klaus.dietz (at) kd-dietz.de
Klaus
The brain isn't a soap, it doesn't shrink when used.
« Reply #6 on: February 26, 2013, 04:41:15 AM »
i emailed the file Klaus
Kenneth
« Reply #7 on: February 26, 2013, 04:58:18 AM »
when i use the "auto enlage screen" i get what you said Brett.
just don't know how to remove the extras in machscreen.
even enlarging the frame doesn't show anything.
Kenneth
« Last Edit: February 26, 2013, 05:01:47 AM by Kenneth »
Kenneth
