Hello Guest it is October 05, 2026, 09:09:42 AM
Author Topic: Dynomotion slave axis problem  (Read 11629 times)
Offline geast
  •  51 51
« on: February 13, 2013, 03:41:19 PM »
Hello everybody.
I install a dynomotion kflop+kanalog boards together with three analog servo drives. The drives takes +-10V and have incremental encoder for feedback.
The X axis has a slave axis A and it is so configured  on mach. Everything works fine when i do cont.jog from mach or a G command G0 Xsomething to the X axis.
The problem is that when i do a step jog or when i execute a g command G01 Xsomething then the slave axis A does not work. Only the X axis rotate.
Can anybody help?
Offline mc
  •  384 384
Re: Dynomotion slave axis problem
« Reply #1 on: February 15, 2013, 03:09:22 PM »
If you've not solved this, your best option is either post on cnczone in the Dynomotion board - http://www.cnczone.com/forums/dynomotion_kflop_kanalog/ or over on the Dynomotion Yahoo Group - http://tech.groups.yahoo.com/group/DynoMotion/
Tom Kerekes (the man behind the KFlop) is very active on both of those.
Offline geast
  •  51 51
« Reply #2 on: February 15, 2013, 04:24:54 PM »
It's solved thank you.
