Hello
Guest
it is
November 22, 2026, 11:39:25 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
almost Newbie lost x axis movement
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: almost Newbie lost x axis movement (Read 23833 times)
Chaoticone
5,624
Precision Chaos
Re: almost Newbie lost x axis movement
Reply #10 on:
February 15, 2013, 07:33:51 AM »
Hey Norm, that xml looks a lot better. It works as it should it here. When you say you lost the x axis, I'm assuming the x axis does not move at all? Does the DRO for the x axis change?
If you could see the things I have in my head, you would be laughing too.
Norm
14
Reply #11 on:
February 15, 2013, 09:39:01 AM »
HI Brett,
The Tool does not move, however the DRO does show the x-axis moving.
Thanks again,
Norm
Carnoustie, Scotland
Reply #12 on:
February 15, 2013, 10:15:26 AM »
Swap pin assignment in Mach for X and Z and see if the Z stops working and X starts (not physical X and Z but Machs X and Z)
Norm
14
Reply #13 on:
February 15, 2013, 01:53:59 PM »
Hi Hood,
I swapped pin assignments. when I jog the x axis Z moves, when I jog the z axis nothing moves. The DRO responds in both Axis.
Any advice will be greatly appreciated.
Thanks again,
Norm
Reply #14 on:
February 15, 2013, 01:58:25 PM »
Ok sounds like a problem with the parallel port I would say.
Norm
14
Reply #15 on:
February 16, 2013, 06:53:00 PM »
Thanks Hood,
I will try hooking it up to a different computer.
Thanks again,
Norm
Print
Pages:
1
2
Go Up
« previous
next »
