Hello Guest it is November 22, 2026, 11:39:23 PM
Author Topic: almost Newbie lost x axis movement  (Read 23832 times)
Offline Norm
  •  14 14
« on: February 13, 2013, 03:26:19 PM »
Hi all,
I was thrilled to have the little Sherline Lathe up and running and I machined a miniature baseball bat.
I moved the setup from home to school but when I went to demonstrate it to one of the other teachers I lost the X axis.  I have lots of spare parts so I replaced the driver box, stepper motor and all cables, thinking that something had been pulled apart in the move.  No luck, and I can not identify any changes in the configuration screens
Any help would be greatly appreciated.
I have attached the xml file in case someone can see the problem there.
Thanks again,
Norm
Re: almost Newbie lost x axis movement
« Reply #1 on: February 13, 2013, 03:42:59 PM »
Swap the axis, ie; Z for X and see if you get movement since at least that may give you an indication of what is wrong.
Offline Norm
  •  14 14
« Reply #2 on: February 13, 2013, 03:48:20 PM »
Thanks Rich,
I will try that right now.
Norm
Offline Norm
  •  14 14
« Reply #3 on: February 13, 2013, 03:56:12 PM »
Tried that and I gained the X axis and lost the Z axis.
Thanks, at least I can rule out hardware now.
Thanks again,
Norm
« Reply #4 on: February 14, 2013, 04:37:44 AM »
Post your xml file that you are using.
Offline Norm
  •  14 14
« Reply #5 on: February 14, 2013, 07:13:19 AM »
Hopefully this is not the third repeat,
Just having a few problems a t this point.
Here is the xml.
Sorry,
Norm
« Reply #6 on: February 14, 2013, 10:56:59 AM »
Norm, you don't have a port number assigned to the step and direction pins in Motor Outputs and you only have the y enabled.  You will want to assign port and pin numbers to the x and z and make sure they are enabled.  You may also need to assign a port and pin to the estop input. I would assign it to port 1 pin 11.  You can change the active state for e stop to over ride it but I do not suggest that, your estop should be priority 1.
Offline Norm
  •  14 14
« Reply #7 on: February 14, 2013, 02:11:31 PM »
Thanks Brett,
Currently, I am using the toogle switch on the Sherline driver box for my ESTOP as suggested by Sherline but only for testing it out.  I will set up an ESTOP shortly and most likely run it through a second printer port.  Thanks for the suggestion it is a very high priority to me also.
I will look again at motor outputs but it appears as that X and Z are enabled and set up on port 1 using 5 & 4 for X and 7&6 for Z.  I will go back through it tomorrow.  I am hoping I didn't send you the old xml file.
Thanks again,
Norm
« Reply #8 on: February 14, 2013, 02:46:03 PM »
OK Norm, you may well have posted an old XML as the only motor enabled is Y.  Also, I didn't see any other inputs assigned.  In any case, I would set the estop pin to pin 11 port 1 for now at least.  The estop must have a port and pin assigned to it, this is not optional.  Weather or not you have it physically wired is up to you but I strongly suggest that you do.
Offline Norm
  •  14 14
« Reply #9 on: February 14, 2013, 08:00:22 PM »
Sorry again for sending the old file last time.  This is the latest version.  I will make the ESTOP a priority.
Thanks again for the continued support.
Norm
