Hello Guest it is November 22, 2026, 11:39:31 PM
Author Topic: almost Newbie lost x axis movement  (Read 23834 times)
Re: almost Newbie lost x axis movement
« Reply #10 on: February 15, 2013, 07:33:51 AM »
Hey Norm, that xml looks a lot better.  It works as it should it here.  When you say you lost the x axis, I'm assuming the x axis does not move at all?  Does the DRO for the x axis change?
Offline Norm
  •  14 14
« Reply #11 on: February 15, 2013, 09:39:01 AM »
HI Brett,
The Tool does not move, however the DRO does show the x-axis moving.
Thanks again,
Norm
« Reply #12 on: February 15, 2013, 10:15:26 AM »
Swap pin assignment in Mach for X and Z and see if the Z stops working and X starts (not physical X and Z but Machs X and Z)
Offline Norm
  •  14 14
« Reply #13 on: February 15, 2013, 01:53:59 PM »
Hi Hood,
I swapped pin assignments.  when I jog the x axis Z moves, when I jog the z axis nothing moves.  The DRO responds in both Axis.
Any advice will be greatly appreciated.
Thanks again,
Norm
« Reply #14 on: February 15, 2013, 01:58:25 PM »
Ok sounds like a problem with the parallel port I would say.
Offline Norm
  •  14 14
« Reply #15 on: February 16, 2013, 06:53:00 PM »
Thanks Hood,
I will try hooking it up to a different computer.
Thanks again,
Norm
